[gdal-dev] densify line?
Dane Springmeyer blake at hailmail.net
Thu Jul 10 13:37:43 EDT 2008
Hi Matt,
ST_Segmentize() in postgis sounds like it might do the trick.
Dane
On Jul 10, 2008, at 9:58 AM, Matt Wilkie wrote:
> Hello All,
> Does ogr have a densify line option or utility?
> The goal is to densify (add vertices at regular intervals) to a 1
> dergree by 1 degree fishnet grid before projecting from WGS84 to UTM
> (or whatever) so the result follows earth curvature rather then
> jumping straight from corner point to corner point.
> I could use Arcinfo DENSIFYARC, but would like to avoid having to
> convert to a coverage if I can.
> thanks,
> matt wilkie
> Geographic Information,
> Information Management and Technology,
> Yukon Department of Environment
> 10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
> 867-667-8133 Tel * 867-393-7003 Fax
> http://environmentyukon.gov.yk.ca/geomatics/
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
