[gdal-dev] gdal 1.5.2 build error on Windows XP
Thu Jul 10 16:48:16 EDT 2008
Gong, Shawn (Contractor) wrote:
> C:\build18\gdal-1.5.2\frmts>cd gtiff   && nmake /NOLOGO /f makefile.vc
> && cd ..
>         cl /nologo /MD /EHsc /Ox /DNDEBUG -I..\..\port -I..\..\ogr
> -I..\..\gcore
>   -I..\..\alg  -Ilibtiff -DBIGTIFF_SUPPORT -Ilibgeotiff  /c geotiff.cpp
> geotiff.cpp
> geotiff.cpp(2744) : error C2520: conversion from unsigned __int64 to
> double not implemented, use signed __int64
Shawn,
I see you are still using VC6!
The offending statement on line 2744 can be safely removed.  I believe it
is just a debug statement.  I ran into the same issue recently in a VC6
build.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
