[gdal-dev] Should we use boolean type at the SWIG interface?
Tamas Szekeres
szekerest at gmail.com
Sun Jul 13 14:02:24 EDT 2008
Or simply
bool TestCapability (const char *cap) {
return (OGR_Dr_TestCapability(self, cap) > 0);
2008/7/13 Tamas Szekeres <szekerest at gmail.com>:
> Frank,
> I'd rather not to change the API as I've suggested before because many
> existing code may rely on it. By using this change the existing
> scripts should use the !=0 suffix in the conditions and this change
> may be confusing.
> What I would propose now is to change the related code according to
> the following example:
> return OGR_Dr_TestCapability(self, cap) > 0? true: false;
> How about this way?
> Tamas
> 2008/7/13 Frank Warmerdam <warmerdam at pobox.com>:
>> Tamas Szekeres wrote:
>>> Devs,
>>> By using boolean type in the SWIG bindings I currently get a number if
>>> warnings when compiling the generated code:
>>> http://buildbot.osgeo.org:8500/builders/szekerest-vc71-full/builds/36/steps/csharp-make/logs/stdio
>>> Since there are no boolean value exposed by the gdal dll I suppose we
>>> can use integers instead of booleans at the wrappers as well.
>>> Any objection to relpace 'bool' with 'int' in ogr.i?
>> Tamas,
>> I believe it would be simplest to expose boolean results as a int.
>> I see that the C API already treats the return result of TestCapability()
>> as an int. I'm not sure why it was done differently in the swig include
>> file.
>> Best regards,
>> I set the clouds in motion - turn up | Frank Warmerdam,
>> light and sound - activate the windows | http://pobox.com/~warmerdam
>> and watch the world go round - Rush | President OSGeo, http://osgeo.org
