[Gdal-dev] Workaround for DataSet.GetGCPs from c#/java?
Tamas Szekeres
szekerest at gmail.com
Mon Jul 14 19:08:28 EDT 2008
FYI: I've just added the implementation for the Dataset.GetGCPs,
Dataset.SetGCPs and GCPsToGeotransform for the C# bindings in the
SVN-trunk. I've added the use cases for these functions in the
GDALWrite and GDALInfo sample applications. Will also apply these in
the stable branch soon.
Best regards,
Tamas
2008/7/11 fevans <fevans at harris.com>:
> OK, c# works for me. Will be on task all weekend so let me know if I can
> help.
> Tamas Szekeres wrote:
>> Hi,
>> This will requre a bindings specific implementation, I'll be trying to
>> implement something in this weekend if this issue is pressing for you.
>> But it will only affect the c# interface, though
>> Best regards,
>> Tamas
>>> I see the milestone for this is GDAL 1.5.3.
>>> http://trac.osgeo.org/gdal/ticket/1677
>>> Is there any other way to access the GCPs in java/c#? For example, would
>>> it
>>> be possible to construct a "SWIGTYPE_p_int", and a
>>> "SWIGTYPE_p_GDAL_GCP[]" ?
>>> I experimented a little but sort of hit a swig wall.
>>> BTW, keep up the great work Tamas.
>>>> 2007/6/19, Jason Beverage <jbeverage at prologic-inc.com>:
>>>>> Hi all,
>>>>> It seems like the signature for DataSet.GetGCPs is incorrect in the C#
>>>>> bindings. It is currently:
>>>>> void DataSet.GetGCPs(SWIGTYPE_p_int nGCPs, SWIGTYPE_p_p_GDAL_GCP pGCPs)
>>>>> It seems like it should be:
>>>>> GCP[] Dataset.GetGCPs();
>>>>> Should I open a ticket?
>>>>> Thanks,
>>>>> Jason
>>>> Yes please, and assign the ticket to the CSharpBindings component
>>>> Best regards,
>>>> Tamas Szekeres
>>>> _______________________________________________
>>>> Gdal-dev mailing list
>>>> Gdal-dev at lists.maptools.org
>>>> http://lists.maptools.org/mailman/listinfo/gdal-dev
>>> View this message in context:
>>> http://www.nabble.com/DataSet.GCPs-Method-in-C--Bindings-tp11197327p18409180.html
>>> Sent from the GDAL - Dev mailing list archive at Nabble.com.
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> View this message in context: http://www.nabble.com/DataSet.GCPs-Method-in-C--Bindings-tp11197327p18409442.html
