[Gdal-dev] Using VRT to project/rotate tiff files on-the-fly
David M Nelson
dnelson99 at gmail.com
Wed Jul 16 17:08:36 EDT 2008
Thanks for the response, Frank. I've been able to parse through and figure
out most of the code. I am a little unclear on the DstGeoTransform part
of the second script. Do I understand that the DstGeoTransform describes
the original projection coordinates and the DstInvGeoTransform describes
the destination projection coordinates (and that everything is in meters)?
I am also not sure about the function of the GCP since the GeoTransform
already defined the UL pixel value? I just want to make sure that I
understand the differences between the control point sets.
Thanks!
David
Frank Warmerdam-2 wrote:
> David M Nelson wrote:
>> I have a series of unprojected, single-frame images. We want to be able
>> to
>> project them on-the-fly by generating a VRT file for each image.
>> However,
>> none of the images are oriented north-up--they are all uniquely oriented
>> because of the flightpath taken by the platform during the time of
>> acquisition. I have not been able to find a way to generate a VRT that
>> takes orientation into account. I tried to use the X-rotation and the
>> Y-rotation, but this completely distorts the image setting some of the
>> coordinate values to 35,000+ deg. I think that the orientation values
>> are
>> supposed to be for the reference frame anyway and not the images (?).
>> So my question is: is there a way to generate a VRT file which will
>> project
>> and orient correctly an unprojected image?
> David,
> If they are still very regularly sampled (only requiring an affine
> transformation to a north up uniform grid) you should be able to express
> the georeferencing with an appropriate geotransform though computing it
> may
> be a bit tricky.
> If the are not necessarily really regular you could create a VRT that
> expresses their georeferencing in terms of georeferenced locations at
> known pixel control points (ie. GCPs). A simple example of an image
> georeferenced with GCPs using a VRT is:
> <VRTDataset rasterXSize="512" rasterYSize="512">
> <Metadata/>
> <GCPList>
> <GCP Id="1" Pixel="0.0000" Line="0.0000" X="1.000000000000E+04"
> Y="5.000000000000E+03"/>
> <GCP Id="2" Pixel="500.0000" Line="0.0000" X="1.200000000000E+04"
> Y="7.000000000000E+03"/>
> <GCP Id="3" Pixel="250.0000" Line="500.0000" X="9.000000000000E+03"
> Y="6.000000000000E+03"/>
> </GCPList>
> <VRTRasterBand dataType="Byte" band="1">
> <Metadata/>
> <ColorInterp>Gray</ColorInterp>
> <SimpleSource>
> <SourceFilename relativeToVRT="1">gcp.tif</SourceFilename>
> <SourceBand>1</SourceBand>
> <SourceProperties RasterXSize="512" RasterYSize="512"
> DataType="Byte"
> BlockXSize="512" BlockYSize="16"/>
> <SrcRect xOff="0" yOff="0" xSize="512" ySize="512"/>
> <DstRect xOff="0" yOff="0" xSize="512" ySize="512"/>
> </SimpleSource>
> </VRTRasterBand>
> </VRTDataset>
> However, this depends on the application reading the image knowing how
> to utilize GCPs which many do not. You could actually rectify the image
> with gdalwarp. But if you don't want to do that you can also create a
> "warped vrt" which is a virtual image representing what gdalwarp would
> have produced. For instance, for the above this might look like:
> <VRTDataset rasterXSize="1448" rasterYSize="724"
> subClass="VRTWarpedDataset">
> <GeoTransform> 7.9520000000000000e+03, 2.8284271247461898e+00,
> 0.0000000000000000e+00, 7.0480000000000000e+03, 0.0000000000000000e+00,
> -2.8284271247461898e+00</GeoTransform>
> subClass="VRTWarpedRasterBand"/>
> <BlockXSize>512</BlockXSize>
> <BlockYSize>128</BlockYSize>
> <GDALWarpOptions>
> <WarpMemoryLimit>6.71089e+07</WarpMemoryLimit>
> <ResampleAlg>NearestNeighbour</ResampleAlg>
> <WorkingDataType>Byte</WorkingDataType>
> <Option name="INIT_DEST">0</Option>
> <SourceDataset relativeToVRT="1">gcp.tif</SourceDataset>
> <Transformer>
> <ApproxTransformer>
> <MaxError>0.125</MaxError>
> <BaseTransformer>
> <GenImgProjTransformer>
> <SrcGCPTransformer>
> <GCPTransformer>
> <Order>1</Order>
> <Reversed>0</Reversed>
> <GCPList>
> X="1.000000000000E+04" Y="5.000000000000E+03"/>
> X="1.200000000000E+04" Y="7.000000000000E+03"/>
> X="9.000000000000E+03" Y="6.000000000000E+03"/>
> </GCPList>
> </GCPTransformer>
> </SrcGCPTransformer>
> <DstGeoTransform>7952,2.82842712474619,0,7048,0,-2.82842712474619</DstGeoTransform>
> <DstInvGeoTransform>-2811.456561997713,0.3535533905932738,0,2491.844296901394,0,-0.3535533905932738</DstInvGeoTransform>
> </GenImgProjTransformer>
> </BaseTransformer>
> </ApproxTransformer>
> </Transformer>
> <BandList>
> <BandMapping src="1" dst="1"/>
> </BandList>
> </GDALWarpOptions>
> </VRTDataset>
> Any GDAL supporting application will read the warped vrt as a north up
> image.
> The commands I used to create the above examples are:
> gdal_translate plain.tif gcp.tif -gcp 0 0 10000 5000
> -gcp 500 0 12000 7000 -gcp 250 500 9000 6000
> gdal_translate gcp.tif gcp.vrt -of VRT
> gdalwarp -of VRT gcp.tif warped.vrt
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
View this message in context: http://www.nabble.com/Using-VRT-to-project-rotate-tiff-files-on-the-fly-tp18448351p18496651.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
