[Gdal-dev] c# Bindings in Mono/Linux
Evans, Frank
fevans at harris.com
Tue Jul 22 11:08:32 EDT 2008
OK, I'll zero in on that. One thing I noticed was that the
"swig/csharp/gdal" directory has a "makefile.vc", but not a GNUmakefile.
During one of my numerous experiments, I manually compiled
"swig/csharp/gdal_wrap.o" by running
gcc -shared -Wl,-soname,libgdal_wrap.so -o libgdal_wrap.so gdal_wrap.o
(or something like that).
Of course the strace output doesn't show any calls to *wrap*. Different
naming convention. This might be irrelevant, but at this point I don't
enough to rule out anything.
I realize that from your perspective this looks like random flailing,
and I have to admit it is. Once again thanks very much for the ideas.
When I finally resolve this, I'll definitely created a detailed post.
-----Original Message-----
From: Tamas Szekeres [mailto:szekerest at gmail.com]
Sent: Tuesday, July 22, 2008 10:49 AM
To: Evans, Frank
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [Gdal-dev] c# Bindings in Mono/Linux
Frank,
It looks like either libgdalcsharp.la or one of it's dependencies is
not available to load, or incorrect version can be loaded with the
current LD_LIBRARY_PATH setting. Please check that the same version of
gdal is loading that the csharp bindings have been compiled against.
Best regards,
Tamas
2008/7/22 Evans, Frank <fevans at harris.com>:
> I agree the dll.config isn't the main issue. I've tried renaming
files,
> linking statically, linking dynamically. After a while,
experimentation
> makes the baseline suspect, so I blast it and start over. Its
definitely
> something on my end. Some basic mistake. I need to get more
> swig-knowledge.
> Thanks again for all your help. BTW, I ran "strace -e trace=open mono
> GDALInfo.exe ..."
> open("libgdalcsharp.la", O_RDONLY|O_LARGEFILE) = 4
> open("./.libs/libgdalcsharp.so.1", O_RDONLY) = 4
> Sent: Monday, July 21, 2008 5:04 PM
> To: Evans, Frank
> Frank,
> I've committed in the SVN trunk to produce well formed xml with the
> development version. However I doubt if it causes this problem.
> Probably your environment settings like incorrect LD_LIBRARY_PATH
> prevents from loading the gdal so or the related so-s (like proj).
> At the buildbot configurations those pathes have been set manually to
> the correct directories.
> Best regards,
> Tamas
> 2008/7/21 fevans <fevans at harris.com>:
>> Tamas, with regards to mono/gdal bindings, I suspect I'm doing
> something
>> wrong in the build process. Clearly the buildbots are passing.
>> One item that's been bothering me is line 50 of
> "swig\csharp\GNUMakefile"
>> Its generating a config-xml wrapper for the dll, but thet XML is
> mal-Formed.
>> echo "<dllmap dll=\""$*"_wrap\" target=\""$@"\">" >>
> $*_csharp.dll.config
>> Generates: <dllmap dll="gdal_wrap" target="libgdalcsharp.la">
>> Should be: <dllmap dll="gdal_wrap" target="libgdalcsharp.la" />
>> So either these wrappers are not used, or I'm digging in the wrong
> place.
>> The nightly builds at "http://buildbot.osgeo.org/gdal-full/" are
still
>> inaccessible.
>> ./mkinterface.sh
>> make -f GNUmakefile
>> make test
>> LC_ALL=C mono createdata.exe Data pointlayer
>> Unhandled Exception: System.TypeInitializationException: An exception
> was
>> thrown by the type initializer for OSGeo.OGR.gr --->
>> System.TypeInitializationException: An exception was thrown by the
> type
>> initializer for OSGeo.OGR.OgrPINVOKE -->
>> An exception was thrown by the type initializer for
> SWIGExceptionHelper --->
>> Systm.DllNotFoundException: libogrcsharp.la
>> at (wrapper managed-to-native)
>> SWIGExceptionHelper:SWIGRegisterExceptionCallbacks_Ogr
(OSGeo.OGR.OgrPINVOKE/SWIGExcepionHelper/ExceptionDelegate,OSGeo.OGR.Ogr
PINVOKE/SWIGExceptionHelper/ExceptionDelegate,OSGeo.OGR.OgrPINVOKE/SWIGE
xceptinHelper/ExceptionDelegate,OSGeo.OGR.OgrPINVOKE/SWIGExceptionHelper
/ExceptionDelegate,OSGeo.OGR.OgrPINVOKE/SWIGExceptionelper/ExceptionDele
gate,OSGeo.OGR.OgrPINVOKE/SWIGExceptionHelper/ExceptionDelegate,OSGeo.OG
R.OgrPINVOKE/SWIGExceptionHeper/ExceptionDelegate,OSGeo.OGR.OgrPINVOKE/S
WIGExceptionHelper/ExceptionDelegate,OSGeo.OGR.OgrPINVOKE/SWIGExceptionH
elpr/ExceptionDelegate,OSGeo.OGR.OgrPINVOKE/SWIGExceptionHelper/Exceptio
> nDelegate,OSGeo.OGR.OgrPINVOKE/SWIGExceptionHelperExceptionDelegate)
>> at OSGeo.OGR.OgrPINVOKE+SWIGExceptionHelper..cctor () [0x00000] ---
> End of
>> inner exception stack trace ---
>> at OSGeo.OGR.OgrPINVOKE..cctor () [0x00000] --- End of inner
> exception
>> stack trace ---
>> at OSGeo.OGR.Ogr..cctor () [0x00000] --- End of inner exception
stack
>> trace ---
>> at CreateData.Main (System.String[] args) [0x00000]
>> make: *** [test] Error 1
>> Tamas Szekeres wrote:
>>> 2008/6/11 Evans, Frank <fevans at harris.com>:
>>>> Tamas, thanks for the test-results link. I had read that tests were
>>>> passing, but the log-detail provided a lot of useful info. I will
> try
>>>> SWIG 1.3.31 this weekend, and let everyone know. I can't switch
mono
>>>> versions, at least not easily. Are the library outputs for the
> automated
>>>> builds accessible?
>>> The build directory of the linux builders used to be accessible from
>>> the following link:
>>> http://buildbot.osgeo.org/gdal-quick/
>>> But it seems like having a permission problem at the moment.
>>>> I know I'm asking for speculation, but do you think there's a
>>>> 32-bit/64-bit issue?
>>> I`ve been trying on debian AMD64 as I`ve noted in my previous post
so
>>> I doubt that this is a 64 bit OS related issue.
>>> The version of swig and mono might even more be an issue.
>>> Best regards,
>>> Tamas
>>> gdal-dev mailing list
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> View this message in context:
http://www.nabble.com/c--Bindings-in-Mono-Linux-tp17709337p18570865.html
>> Sent from the GDAL - Dev mailing list archive at Nabble.com.
