[gdal-dev] Filling in holes when warping
Frank Warmerdam
warmerdam at pobox.com
Tue Jul 22 12:18:18 EDT 2008
Andrew Brooks wrote:
> Hi
> I'm getting the following holes:
> http://www.sat.dundee.ac.uk/~arb/gdalwarp.jpg
> when I use gdalwarp on an image with a geolocation array.
> Should I file a bug?
Andrew,
You can file a bug. I imagine this is a limitation of the "hole filling"
code:
http://trac.osgeo.org/gdal/browser/trunk/gdal/alg/gdalgeoloc.cpp#L267
You might want to try changing this code to go more than 3 iterations and
see if it helps.
It might be best to make this go till no more filling needs to be done or
too use a more general purpose hole filling approach.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
