[gdal-dev] ogrinfo and gml?
Mateusz Loskot
mateusz at loskot.net
Fri Jul 25 08:58:54 EDT 2008
Christopher Schmidt wrote:
>>> On Fri, Jul 25, 2008 at 12:37:38PM +0200, Mateusz Loskot wrote:
>>>> Wendell Turner wrote:
>>>>> Why do the examples of ogrinfo not work? That is, the
>>>>> example shows a coal_dep.gml with contents of:
>>>>> <gml:featureMember>
>>>>> <Coal_Deposits fid="1">
>> Yes, I agree the prolog is optional, but GML driver expects to find
>> target namespace in the root element.
> Right, which means the prolog is not the problem here -- the fact that
> this is an illegal XML document is. :)
Yes, Chris, you are perfectly correct.
I always use XML prolog, so I assumed myself it's not optional.
I should read the XML spec more carefully instead :-)
> Specifically, it's a namespaced doc with no namespace declarations.
Yes.
Ciao
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
