[gdal-dev] CADRG subdataset access help
Frank Warmerdam
warmerdam at pobox.com
Fri Jul 25 15:51:43 EDT 2008
Christiaan Janssen wrote:
> How exactly does one go about accessing the raster data in an format that
> contains subdatasets like CADRG? Any help would be greatly appreciated.
Christiaan,
Are you working programmatically or as a user with end-user tools like gdalinfo
and gdal_translate?
For an end user, one would normally run gdalinfo against the file/dataset and
see the reported subdataset names. Then run gdalinfo or gdal_translate against
the desired subdataset name.
Scripts/applications operate similarly, fetching the subdataset names from
metadata.
You may find it helpful to read the section titled "SUBDATASETS Domain" in
this doc:
http://www.gdal.org/gdal_datamodel.html
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
