[gdal-dev] CADRG subdataset access help
Frank Warmerdam
warmerdam at pobox.com
Fri Jul 25 16:53:52 EDT 2008
Christiaan Janssen wrote:
> I'm working programmatically. I sort of understand the mechanism described in the suggested document but would greatly appreciate a short snippet to show how one goes about opening the subdataset. I'm guessing in the example described on the web page that to open the first dataset I would call GDALOpen as follows:
> GDALOpen("NITF_IM:0:multi_1b.ntf", GDALAccess::GA_ReadOnly);
Christiaan,
Yes, though you don't normally need to qualify GA_ReadOnly. The following
code chunk out of gdal_translate (used to recurse over subdatasets) might
also be helpful.
/* Handle subdatasets. */
if( CSLCount(GDALGetMetadata( hDataset, "SUBDATASETS" )) > 0 )
if( !bCopySubDatasets )
fprintf( stderr,
"Input file contains subdatasets. Please, select one of
them for reading.\n" );
else
char **papszSubdatasets = GDALGetMetadata(hDataset,"SUBDATASETS");
char *pszSubDest = (char *) CPLMalloc(strlen(pszDest)+32);
int i;
int bOldSubCall = bSubCall;
argv[iDstFileArg] = pszSubDest;
bSubCall = TRUE;
for( i = 0; papszSubdatasets[i] != NULL; i += 2 )
argv[iSrcFileArg] = strstr(papszSubdatasets[i],"=")+1;
sprintf( pszSubDest, "%s%d", pszDest, i/2 + 1 );
if( ProxyMain( argc, argv ) != 0 )
break;
bSubCall = bOldSubCall;
CPLFree( pszSubDest );
GDALClose( hDataset );
if( !bSubCall )
GDALDumpOpenDatasets( stderr );
GDALDestroyDriverManager();
return 1;
and watch the world go round - Rush | President OSGeo, http://osgeo.org
