[gdal-dev] GDAL on 64 bit environments
Mateusz Loskot mateusz at loskot.net
Mon Jul 28 05:58:05 EDT 2008
Gianni Barrotta wrote:
> Ok, I'm going to try with the 32 bit FWTools, probably it won't use the full
> 64 bit CPU, am I wrong?
Regarding performance advantage, generally speaking, yes it won't.
Your programs will run as it are executed on 32-bit system.
Specifically, depends on actual architecture [1]
[1] http://en.wikipedia.org/wiki/64-bit#32_vs_64_bit
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
