[gdal-dev] GDAL in 64bits Linux environment
Nidel, Mike mike.nidel at lmco.com
Wed Jul 30 15:06:10 EDT 2008
You're right, I didn't read carefully enough.
I had a problem with not finding libjpeg.la so i disabled
libtool and it solved the problem. Now whenever I see
"libXYZ.la" that's what I always think of. Flashbacks,
I suppose. :)
> -----Original Message-----
> From: Even Rouault [mailto:even.rouault at mines-paris.org]
> Sent: Wednesday, July 30, 2008 2:59 PM
> To: gdal-dev at lists.osgeo.org
> Cc: Limei Ran; Nidel, Mike
> Subject: Re: [gdal-dev] GDAL in 64bits Linux environment
> Well, clearly the problem is /usr/lib/libexpat.so that must
> be 32 bit on your distro. It should fetch
> /usr/lib64/libexpat.so instead. I think someone reported
> similar problem not so long ago on the mailing list. You
> should fetch the archives to see if there was a solution.
> Otherwise you can try to patch GDALmake.opt generated by
> configure to correct this, or compile without expat if you
> don't need KML and GPX read support.
> Le Wednesday 30 July 2008 20:52:52 Limei Ran, vous avez écrit :
> > Hi Mike:
> > Thanks for your reply and the following is my error:
> > libtool: link: creating GNU ld script: .libs/libgdal.la.lnkscript
> > libtool: link: g++ -shared -nostdlib
> > /usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64/crti.o
> > /usr/lib/gcc/x86_64-redhat-linux/4.1.2/crtbeginS.o
> > .libs/libgdal.la.lnkscript  -Wl,-rpath
> >-Wl,/nas/uncch/depts/cep/emc/lran/mims/mimssp_8_2008/src/libs
> /proj-4.6.
> >0/lo
> >cal/lib -Wl,-rpath
> /proj-4.6.
> >0/lo
> >cal/lib
> >-L/nas/uncch/depts/cep/emc/lran/mims/mimssp_8_2008/src/libs/p
> roj-4.6.0/
> >loca
> >l/lib
> >/nas/uncch/depts/cep/emc/lran/mims/mimssp_8_2008/src/libs/pro
> j-4.6.0/lo
> >cal/ lib/libproj.so -lsqlite3 -L/usr/lib /usr/lib/libexpat.so -lgif
> >-ljpeg -ltiff  -lpng -lz -lrt -ldl
> >-L/usr/lib/gcc/x86_64-redhat-linux/4.1.2
> > -L/usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64
> > -L/lib/../lib64 -L/usr/lib/../lib64 -lstdc++ -lm -lc -lgcc_s
> >/usr/lib/gcc/x86_64-redhat-linux/4.1.2/crtendS.o
> > /usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64/crtn.o
> > -Wl,-soname -Wl,libgdal.so.1 -o .libs/libgdal.so.1.12.2
> > /usr/lib/libexpat.so: could not read symbols: File in wrong format
> > collect2: ld returned 1 exit status
> > make[1]: *** [libgdal.la] Error 1
> > make[1]: Leaving directory
> `/nas/uncch/depts/cep/emc/lran/mims/mimssp_8_2008/src/libs/gdal-1.5.2'
> > make: *** [check-lib] Error 2
> > In the old 32bits environment, it worked fine.
> > Thanks,
> > Limei
> > Nidel, Mike wrote:
> > >I've gotten it to work using the 1.5 branch. I didn't have to do
> > >anything specific to 64-bit as far as I know. What are your errors?
> > >Mike
> > >>From: gdal-dev-bounces at lists.osgeo.org
> > >>[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Limei Ran
> > >>Sent: Wednesday, July 30, 2008 2:03 PM
> > >>Subject: [gdal-dev] GDAL in 64bits Linux environment
> > >>Hi:
> > >>I am having some errors in compiling GDAL on our new 64bits Linux
> > >>server.  Could you tell me whether gdal1.5.2 has been tested on
> > >>64bit Linux or what I need to change in the configure file?
> > >>Thanks,
> > >>Limei
> > >>_______________________________________________
> > >>gdal-dev mailing list
> > >>http://lists.osgeo.org/mailman/listinfo/gdal-dev
