[gdal-dev] help using gdal_grid ...
Paul Spencer pagameba at gmail.com
Sun Jun 1 21:16:08 EDT 2008
I have a set of x,y,z data in text files.  There are about 1800
individual files.  Each file has several thousand points.  The sum
total is about 14.5 million entries.
I would like to convert this into a DEM so I can make contours and
hillshade.
My first attempt has been to concatenate all the files into a single
file, create a VRT file, and run gdal_grid on the resulting file.  It
took about 4 hours for gdal_grid (running at 99.5% of one core on my
macbookpro) to output the first '0' in the progress monitor so I
abandoned this process :)
So I would like some advice on how to tune the parameters to gdal_grid
to get reasonable results in a more suitable amount of time.
The data has been collected at approximately 70 meter intervals or
less depending on the terrain.
The area of coverage is in ESPG:2036 and is
2302989.998137,7597784.001173 - 2716502.001863,7388826.998827
which is about 413000 m x 209000 m
Questions:
* what is a reasonable -outsize value?  Originally I though 5900 x
3000 based on the 70 m per measurement thing, but perhaps that is way
too big?
* invdist seems to be the slowest algorithm based on some quick tests
on individual files.  Is there much difference between average and
nearest?  What values of radius1 and radius2 will work the fastest
while still producing reasonable results of the -outsize above?
* would it be better to convert from CSV to something else (shp?) first?
* would it be better to process individual input files then run
gdal_merge.py on the result?
Cheers
Paul
   Paul Spencer
   Chief Technology Officer
   DM Solutions Group Inc
   http://www.dmsolutions.ca/
