[gdal-dev] Re: Byte swapping (esp for ENVI format output) & RSAT2doc
Gong, Shawn (Contractor) Shawn.Gong at drdc-rddc.gc.ca
Fri Jun 6 09:55:33 EDT 2008
hi Paul  and list,
RadarSat document RN-RP-51-27 can be found at
http://www.radarsat2.info/product/51-2713_-_RSAT-2_Product_Format_Defini
tion_-_Iss1_7.pdf
Shawn
-----Original Message-----
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Paul Mallas
Sent: Friday, June 06, 2008 9:47 AM
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] Re: Byte swapping (esp for ENVI format output) &
RSAT2doc
Get lost you loser.
Just wanted one response.
Paul Mallas wrote:
> Hello,
> Does any gdal utility (like gdal_translate) have the capacity to byte
> swap data, especially for the ENVI output format?  I have poked around
a
> bit in the documents and the answer seems to be "no."  But byte
swapping
> seems like something that some gdal utility should do.
> Also, the GDAL RS2 xml product page references RadarSat document
> RN-RP-51-27. I have hunted around the internet and not found it.  Is
it
> available somewhere?
> Thanks,
> Paul
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
