[gdal-dev] Re: Byte swapping (esp for ENVI format output) & RSAT2
doc
Christopher Barker
Chris.Barker at noaa.gov
Fri Jun 6 12:00:05 EDT 2008
> Paul Mallas wrote:
>> Does any gdal utility (like gdal_translate) have the capacity to byte
>> swap data, especially for the ENVI output format?
I don't know if there is a way for GDAL to do it, but it would be a
pretty short scrip tin python with numpy -- load the rasterband into a
numpy array, byteswap it, then save it back.
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R (206) 526-6959 voice
7600 Sand Point Way NE (206) 526-6329 fax
Seattle, WA 98115 (206) 526-6317 main reception
