[gdal-dev] Re: Byte swapping (esp for ENVI format output) &
RSAT2 doc
Frank Warmerdam
warmerdam at pobox.com
Fri Jun 6 13:10:58 EDT 2008
Paul Mallas wrote:
> Thanks for the note - I went ahead and wrote a small c++ program to do
> this.
> Pretty easy to implement, but it seemed like something that would be in
> the gdal utilities.
> Christopher Barker wrote:
>>> Paul Mallas wrote:
>>>> Does any gdal utility (like gdal_translate) have the capacity to
>>>> byte swap data, especially for the ENVI output format?
>> I don't know if there is a way for GDAL to do it, but it would be a
>> pretty short scrip tin python with numpy -- load the rasterband into a
>> numpy array, byteswap it, then save it back.
Paul,
If you prepare a VRT file description of a raw file you can describe
the byte order of the data. Some of the other "raw file header" formats
also include byte order information.
http://www.gdal.org/gdal_vrttut.html (scan for "Descriptions for raw files")
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
