[gdal-dev] Image values greater than the maximum.
Even Rouault
even.rouault at mines-paris.org
Wed Jun 11 14:01:34 EDT 2008
Michele,
Here's what I tried on 1.5 SVN branch :
even at pc-amd64:~/downloads/mapserver/gdal.svn.commit/branches/1.5/gdal$
apps/gdalinfo -stats ../../../gdal/095b_dem_90m.asc
Driver: AAIGrid/Arc/Info ASCII Grid
Files: ../../../gdal/095b_dem_90m.asc
Minimum=213.000, Maximum=578.000, Mean=354.816, StdDev=83.352
NoData Value=-9999
apps/gdalinfo -approx_stats ../../../gdal/095b_dem_90m.asc
Minimum=213.000, Maximum=538.000, Mean=355.264, StdDev=83.247
NoData Value=-9999
So, with bApproxOK=FALSE, the maximum is 578, where as with bApproxOK=TRUE it
is 538. But, but, but, I had to remove the 095b_dem_90m.asc.aux.xml file that
stores these results of computations. So I guess it is at the root of the
strange phenomena you see.
You have probably done the first time an approximate computation, that was
stored in the .aux.xml file, and then when you ask for an exact computation
it finds the values in the .aux.xml file and doesn't compute them afterwards.
I don't think the bApproxOK paramater can have any influence on the RasterIO
result (and really can't see how it could), but you probably got confused by
the order in which you did all those operations.
Le Wednesday 11 June 2008 09:57:24 Michele Sanges, vous avez écrit :
> I noticed a problem in my code; it's reproducible with the
> Arc/Info_ASCII_GRID gdal dataset taken from:
> http://download.osgeo.org/gdal/data/aaigrid/095b_dem_90m.asc
> If I call the function GDALComputeRasterMinMax() with the second
> parameter 'bApproxOK' set to FALSE, I get the values:
> * min=213
> * max=538
> Then, when I go to read the image with the ReadIO function, all of the
> values are within this range and this is ok.
> Instead if I call the function GDALComputeRasterMinMax() with the second
> parameter 'bApproxOK' set to TRUE, I get the same above min and max
> values but when I go to read the image, some of the values are greater
> than the maximum.
> Why the parameter 'bApproxOK' has influence on the values of data?
> Thanks.
> Michele
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
