[gdal-dev] osm xml and everything else
Tim Bowden
tim.bowden at westnet.com.au
Thu Jun 12 03:15:58 EDT 2008
On Thu, 2008-06-12 at 07:59 +0100, Martin Daly wrote:
> > I understand there was talk about an ogr-osm driver. Did it ever get
> > anywhere? If so, what state is it in? If not, what is the current
> > recommended route to getting data between osm and everything else?
> I'm
> > wanting to take snippets of osm xml and in the first instance, put it
> in
> > kml. Ultimately, I'm wanting it in postgis where I can make real use
> of
> > it. I'd also like to be able to easily suck new data out of postgis
> > into something osm can use. Recommendations?
> http://svn.openstreetmap.org/applications/utils/export/
> http://svn.openstreetmap.org/applications/utils/export/osm2kml/
> http://svn.openstreetmap.org/applications/utils/export/osm2pgsql/
> http://svn.openstreetmap.org/applications/utils/import/
> M
Thanks Martin, just goes to show how much I know about osm!
Regards,
Tim Bowden
