[gdal-dev] Problems compiling GDAL 1.5.1
Even Rouault
even.rouault at mines-paris.org
Thu Jun 19 13:42:17 EDT 2008
This bug was known as http://trac.osgeo.org/gdal/ticket/2317 and has been
fixed in GDAL 1.5.2.
So, just upgrade ;-)
Le Thursday 19 June 2008 01:12:16 Bill Thoen, vous avez écrit :
> I ran into a problem compiling GDAL 1.5.1 on my Linux Fedora Core 9
> system. The error seems to be caused by max and min macros with the
> wrong number of parameters. Anyone else run into this and what's the fix?
> Below is the relevant section of the log that reported this:
> /bin/sh /home/bthoen/Install/gdal-1.5.1/libtool --mode=compile --tag=CXX
> g++ -g -O2 -Wall -I. -I.. -I../..
> -I/home/bthoen/Install/gdal-1.5.1/port
> -I/home/bthoen/Install/gdal-1.5.1/gcore
> -I/home/bthoen/Install/gdal-1.5.1/alg
> -I/home/bthoen/Install/gdal-1.5.1/ogr
> -I/home/bthoen/Install/gdal-1.5.1/ogr/ogrsf_frmts -DOGR_ENABLED
> -I/home/bthoen/Install/gdal-1.5.1/port -c -o ../o/ogrgeojsonlayer.o
> ogrgeojsonlayer.cpp
> libtool: compile: g++ -g -O2 -Wall -I. -I.. -I../..
> -I/home/bthoen/Install/gdal-1.5.1/port -c ogrgeojsonlayer.cpp -fPIC
> -DPIC -o ../o/.libs/ogrgeojsonlayer.o
> In file included from
> /usr/lib/gcc/i386-redhat-linux/4.3.0/../../../../include/c++/4.3.0/bits/stl
>_algo.h:66, from
> /usr/lib/gcc/i386-redhat-linux/4.3.0/../../../../include/c++/4.3.0/algorith
>m:67, from ogrgeojsonlayer.cpp:32:
> /usr/lib/gcc/i386-redhat-linux/4.3.0/../../../../include/c++/4.3.0/bits/alg
>orithmfwd.h:248:41: error: macro "max" passed 3 arguments, but takes just 2
>orithmfwd.h:259:41: error: macro "min" passed 3 arguments, but takes just 2
>_algo.h:66, from
>orithmfwd.h:244: error: expected unqualified-id before 'const'
>orithmfwd.h:244: error: expected `)' before 'const'
>orithmfwd.h:244: error: expected initializer before 'const'
>orithmfwd.h:248: error: template declaration of 'const _Tp& std::max'
>orithmfwd.h:255: error: expected unqualified-id before 'const'
>orithmfwd.h:255: error: expected `)' before 'const'
>orithmfwd.h:255: error: expected initializer before 'const'
>orithmfwd.h:259: error: template declaration of 'const _Tp& std::min'
>_algo.h: In function 'void std::__merge_sort_loop(_RandomAccessIterator1,
> _RandomAccessIterator1, _RandomAccessIterator2, _Distance)':
>_algo.h:2884: error: expected unqualified-id before '(' token
> _RandomAccessIterator1, _RandomAccessIterator2, _Distance, _Compare)':
>_algo.h:2908: error: expected unqualified-id before '(' token
> ogrgeojsonlayer.cpp: In member function 'void
> OGRGeoJSONLayer::DetectGeometryType()':
> ogrgeojsonlayer.cpp:377: warning: unused variable 'lyrType'
> make[3]: *** [../o/ogrgeojsonlayer.o] Error 1
> make[3]: Leaving directory
> `/home/bthoen/Install/gdal-1.5.1/ogr/ogrsf_frmts/geojson'
> make[2]: *** [geojson-target] Error 2
> make[2]: Leaving directory
> `/home/bthoen/Install/gdal-1.5.1/ogr/ogrsf_frmts' make[1]: *** [sublibs]
> Error 2
> make[1]: Leaving directory `/home/bthoen/Install/gdal-1.5.1/ogr'
> make: *** [ogr-target] Error 2
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
