[gdal-dev] ogr2ogr projection problem
Guillaume Sueur
guillaume.sueur at neogeo-online.net
Sat Jun 21 04:53:27 EDT 2008
actually, isn't it already the problem described in ticket 481 :
ogr2ogr: SHAPE-> MapInfo conversion - proj info get's lost
it seems to apply to MapInfo -> MapInfo reprojection as well then.
Guillaume
Frank Warmerdam a écrit :
> Guillaume Sueur wrote:
>> Hi,
>> I've noticed a problem using ogr2ogr for MapInfo files creation. the
>> destination projection doesn't seem to be set in the resulting file,
>> causing MapInfo opening it as 'non earth projection'.
>> Here is the ogrinfo of my input file :
>> PROJCS["unnamed",
>> GEOGCS["unnamed",
>> DATUM["NTF_Paris_Meridian",
>> SPHEROID["Clarke 1880 (modified for
>> IGN)",6378249.2,293.4660213],
>> TOWGS84[-168,-60,320,-0,-0,-0,0]],
>> PRIMEM["non-Greenwich",2.337229166667],
>> UNIT["degree",0.0174532925199433]],
>> PROJECTION["Lambert_Conformal_Conic_2SP"],
>> PARAMETER["standard_parallel_1",43.199291275544],
>> PARAMETER["standard_parallel_2",44.996093814511],
>> PARAMETER["latitude_of_origin",44.1],
>> PARAMETER["central_meridian",0],
>> PARAMETER["false_easting",600000],
>> PARAMETER["false_northing",200000],
>> UNIT["Meter",1.0]]
>> but the same transformation for a mapInfo file gives back :
>> Layer SRS WKT:
>> LOCAL_CS["Nonearth",
>> UNIT["Meter",1.0]]
>> these commands with s_srs instead of a_srs gives the same results.
> Guillaume,
> There is something about this coordinate system that OGR's mapinfo
> driver does not know how to represent in mapinfo tab or mif format.
> I'm not sure exactly what. Certainly the non-greenwich prime meridian
> is likely an issue. Perhaps the LCC projection is also not supported.
> I would suggest you file a ticket on this issue, but I am doubtful anything
> will change in the near future. I expect more straightforward coordinate
> systems will work.
> Best regards,
