[gdal-dev] TILED=NO creates a tiled TIFF?
Maciej Sieczka
tutey at o2.pl
Mon Jun 23 04:35:09 EDT 2008
Frank Warmerdam pisze:
> Maciej Sieczka wrote:
>> Thanks for the hint. Unfortunatelly gdal_translate segfaults then:
>> Starting program: /usr/local/bin/gdal_translate -co "TILED=YES" -co
>> "BLOCKYSIZE=1" check.tif check3.tif
> It appears you switched back to TILED=YES from TILED=NO.
Sorry! It was late.
> A blockysize of
> 1 is not legal for tiled files. I'm not sure why things crashed though.
> You might want to file a ticket on that aspect.
Will do.
> But try:
> gdal_translate -co TILED=NO -co BLOCKYSIZE=1 check.tif check3.tif
Seems to work, but throws out an error:
$ gdal_translate -co "TILED=NO" -co "BLOCKYSIZE=1" check.tif check3.tif
Input file size is 4090, 2216
ERROR 1: TIFFReadDirectory:Cannot handle zero number of tiles
0...10...20...30...40...50...60...70...80...90...100 - done.
Is everything OK?
Maciek
Maciej Sieczka
www.sieczka.org
