[gdal-dev] gdalwarp - source srs definition
Frank Warmerdam
warmerdam at pobox.com
Fri Jun 27 09:44:12 EDT 2008
Volker Wichmann wrote:
> I do not define -s_srs, as I suspect it is read from the input files
> when I look in the gdalwarp code. The strange thing is now, that
> gdalwarp sometimes reports
> ERROR 1: Failed to import coordinate system `'.
> on some of the rasters and thus does not write the projection info to
> the output file. When I run gdalinfo on each input file, everything is
> reported correctly.
> Has anybody encountered this too and could give me some hints?
Volker,
This sounds like some subtle kind of bug. If you can isolate one particular
file that demonstrates is it might be appropriate to file a bug on the
problem. You can just provide the portion of the ascii grid file up to
the start of the raster values.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
