[gdal-dev] gdalwarp - source srs definition
Fri Jun 27 16:01:36 EDT 2008
Volker Wichmann wrote:
> Frank,
> while building a test case for a bug report I was working on a machine
> where GDAL 1.5.1 is installed - and encountered no problems. The problem
> seems to be solved in this version, although I'm not sure about what
> makes the difference when looking at the changes history since GDAL
> 1.4.3.0.
> Trying the test case again with GDAL 1.4.3.0 reproduces the error.
> I'm not sure if it's appropriate to file a bug report?
Volker,
No, there is little point filing a ticket if you can't reproduce the
problem with the current code.  It was quite possibly fixed, perhaps
as a side effect of some other fix or change.
> Anyway, we're planning to upgrade all our GDAL versions soon. Doing so
> would be really facilitated if there would be some 'make dist clean'
> available for GDAL - so this is somewhat a feature request ;-)  Or is it
> save to just remove the old sources and build the new ones?
I thought you were going to request "make uninstall".  I'm not sure what
you think "make dist clean" would do.  There is already a clean target.
Generally speaking upgrading can be accomplished by pulling down a new source
tree, building and installing it over the old installed tree.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
