[gdal-dev] a complete list of GDAL supported EPSG codes
Maciej Sieczka
tutey at o2.pl
Mon Jun 30 15:00:01 EDT 2008
Frank Warmerdam pisze:
>>> 900913 is not really an EPSG code.
>> Yes I know.
>>> Do you want real EPSG codes or also every other crappy thing
>>> someone has pushed into the EPSG name space for some special
>>> purpose?
>> The latter. Ie. all the codes that epsg_tr.py is able to process -
>> like the 900913.
> There is no uniform mechanism to accomplish this. You can just give
> epsg_tr.py a wide numeric range and it will try everything in the
> range but it will likely take an inordinate amount of time.
How about the former then - how do I best fetch the list of *real* EPSG
codes that my instalation of GDAL is able to recognize? Is extracting
them from pcs.csv and gcs.csv a good approach?
Thanks,
Maciek
Maciej Sieczka
www.sieczka.org
