[Gdal-dev] How to read SEP dataset using GDAL
Martin Chapman
mchapman at texelinc.com
Sat Mar 1 15:23:44 EST 2008
The format name SEP is not listed on the page
http://www.gdal.org/formats_list.html of gdal supported formats so I would
think the answer is that gdal does not currently support the SEP format. If
you want to be sure you could try to use the utility gdalinfo that comes
with gdal and see if it can open the file. See
http://www.gdal.org/gdalinfo.html for more information.
Martin
-----Original Message-----
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of bargi
Sent: Saturday, March 01, 2008 2:29 AM
To: gdal-dev at lists.osgeo.org
Subject: [Gdal-dev] How to read SEP dataset using GDAL
Is there a way to read the SEP dataset using GDAL...???????/
Can Anybody give me step to do that ??
Thanks
View this message in context:
http://www.nabble.com/How-to-read-SEP-dataset-using-GDAL-tp15773073p15773073
.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
