[gdal-dev] ogr2ogr and GPX files
Tamas Szekeres
szekerest at gmail.com
Tue Mar 4 04:33:18 EST 2008
Yes, you should try with the recent SVN version. The changes related
to this issue are pretty new.
Best regards,
Tamas
2008/3/4, Dylan Beaudette <dylan.beaudette at gmail.com>:
> On Monday 03 March 2008, Even Rouault wrote:
> > In fact, using the same principle, you can use just one command line and no
> > intermediary file :
> > ogr2ogr -f GPX destination.gpx source.shp -sql "SELECT src_field_1 AS
> > name, src_field_2 AS desc FROM your_source_layer_name"
> > Thanks to FrankW for the tip ;-)
> Thanks Even / Frank.
> One small problem:
> ogr2ogr -t_srs '+proj=latlong +datum=WGS84' \
> -f GPX -dsco GPX_USE_EXTENSIONS=YES \
> veg_points.gpx veg_points.shp \
> -sql "SELECT cat AS foo FROM veg_points"
> ERROR 1: SQL: Missing comma after column cat in SELECT statement.
> Could this be a bug or my version of GDAL too old ? This is with GDAL SVN,
> checked out a couple of weeks ago.
> I get a valid GPX file if I do not use the "AS foo" operator.
> Ideas?
> Dylan
> > Le Monday 03 March 2008 19:43:12 Even Rouault, vous avez écrit :
> > > Hi,
> > > I see your point...
> > > The solution is the powerful OGR Virtual Dataset format !
> > > See http://www.gdal.org/ogr/drv_vrt.html
> > > In fact, the documentation should probably be extended to demonstrate the
> > > power of the OGR SQL for that particular case
> > > Try to paste the following lines in a file (remapped_layer.vrt would be
> > > fine)
> > > <OGRVRTDataSource>
> > > <OGRVRTLayer name="remapped_layer">
> > > <SrcDataSource>your_source.shp</SrcDataSource>
> > > <SrcSQL>SELECT src_field_1 AS name, src_field_2 AS desc FROM
> > > your_source_layer_name</SrcSQL>
> > > </OGRVRTLayer>
> > > </OGRVRTDataSource>
> > > Replace your_source.shp, src_field_1, src_field_2 and
> > > your_source_layer_name by the appropriate values from your source dataset
> > > and 'ogrinfo -ro -al remapped_layer.vrt' should show a structure
> > > compatible of a GPX file.
> > > Best regards,
> > > Even
> > > Le Monday 03 March 2008 07:04:41 Dylan Beaudette, vous avez écrit :
> > > > Hi,
> > > > is there a simple approach (via ogr2ogr) to create GPS files which have
> > > > standard waypoint tags such as <name>, <elev>, <cmt>, etc. by
> > > > re-mapping columns in the attribute table of the source vector?
> > > > for example:
> > > > # export points vector from GRASS
> > > > v.out.ogr in=wp type=point dsn=wp.shp
> > > > # convert tp GPX:
> > > > wp_gps.gpx wp.shp
> > > > This results in a working GPX waypoints file, that when uploaded to a
> > > > GPS is functional, but the waypoints are all re-named sequentially.
> > > > Note that I am uploading the GPX file the GPS via gpsbabel.
> > > > Does anyone know of the appropriate incantation that one could use to
> > > > translate the column structure of the input wp.shp (i.e. the stuff in
> > > > its .dbf) into standard waypoint tags?
> > > > thanks in advance!
> > > > PS: trying to write a simple tutorial for some colleagues [1]
> > > > 1. http://casoilresource.lawr.ucdavis.edu/drupal/node/553
> > > _______________________________________________
> > > gdal-dev mailing list
> > > gdal-dev at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Dylan Beaudette
> Soil Resource Laboratory
> University of California at Davis
> 530.754.7341
