[Gdal-dev] GDAL WMS Questions..
Fodder
cryan at csse.com.au
Sun Mar 9 20:07:41 EDT 2008
Adam Nowacki wrote:
> If you're getting null (0) and no error message then either you have no
> wms driver built in or the xml doesnt start with <GDAL_WMS>.
ok, well the xml does start with <GDAL_WMS>. I'm using the FWTools 2.06
package so I assume the WMS driver should be included, is there someway I
can check?
View this message in context: http://www.nabble.com/GDAL-WMS-Questions..-tp15866625p15948582.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
