[gdal-dev] HDF5 1.8? DAP 3.8?
Lucena, Ivan ivan.lucena at pmldnet.com
Thu Mar 13 09:00:51 EDT 2008
Javier,
Never mind. I've got it. I downloaded the binaries for VC2005 and added
the flag to frmts\hdf5\makefile.vc and it is seams to be working.
One question:
Since the HDF5 driver is read-only, do you know of any free tool that
converts from bigtiff (or other GDAL big raster container) to HDF5?
Thanks
Ivan
Lucena, Ivan wrote:
> Javier,
> I believe that the configuration flag is H5_USE_16API.
> Did you apply this flag to the HDF library or to the HDF5 driver in GDAL?
> Best regards,
> Ivan
> Javier Urien wrote:
>> I am using gdal with HDF5 1.8 and if you compile it so that it uses
>> APIv1.6 (forgot the configure flag) it works fine.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
