[gdal-dev] Bounding box restriction in WCS driver
Thu Mar 20 15:50:05 EDT 2008
Lúbia Vinhas wrote:
> Hi,
> I'm trying to use the GDAL driver to access a WCS server,
> and it worked fine. Except that it seems that it doesn't recognize
> the bounding box restriction... it always returns the entire coverage.
> I tried two different descriptions for the coverage:
> 1)  using the GDAL elements:
> <WCS_GDAL>
> <ServiceURL>http://nsidc.org/cgi-bin/atlas_north?SERVICE=WCS&amp;request=GetCoverage&amp;crs=EPSG:32661</ServiceURL>
> <CoverageName>sea_ice_concentration_01</CoverageName>
> <PreferredFormat>GeoTIFF</PreferredFormat>
> <GetCoverageExtra>&amp;resx=25000&amp;resy=25000&amp;bbox=-2500000,-2500000,6700000,6700000</GetCoverageExtra>
> </WCS_GDAL>
> 2) setting the parameters in the serviceURL  element:
> <WCS_GDAL>
> <ServiceURL>http://nsidc.org/cgi-bin/atlas_north?SERVICE=WCS&amp;request=GetCoverage&amp;crs=EPSG:32661&amp;format=GeoTIFF&amp;resx=25000&amp;resy=25000&amp;bbox=-2500000,-2500000,6700000,6700000</ServiceURL>
> </WCS_GDAL>
> I always get the entire coverage, even when I specify a smaller BB. The server
> works fine, I mean it responds to different bounding boxes or resolutions when
> being accessed by other clients.
> Can anyone give me a hint about it?
Lúbia,
The GDAL WCS driver will always push it's own BBOX values into the URL
it uses internally to make requests, so it is dangerous to put a BBOX
into either the base url or the GetCoverageExtra as this results in two
BBOXes being sent to the remote server.
Ideally you would just request a subarea of the whole coverage
from GDAL instead of trying to configure the WCS service to only
know about a subarea.
So for instance, do something like:
gdal_translate -projwin 2500000 -2500000 6700000 6700000 your.wcs out.tif
Then the GDAL driver should only make the necessary requests to satisfy your
request (or possibly a little extra if it is doing it in tile oriented
chunks).
If you really wanted to treat it as a restricted WCS you would need to
substantially doctor the coverage fetched and kept in the XML service
file.  For instance, in a WCS 1.0 service you could modify:
         <RectifiedGrid dimension="2">
           <limits>
             <GridEnvelope>
               <low>0 0</low>
               <high>189235 273028</high>
             </GridEnvelope>
           </limits>
           <axisName>x</axisName>
           <axisName>y</axisName>
           <origin>
             <pos>-82.351242 13.0499433</pos>
           </origin>
           <offsetVector>0.00025602 0</offsetVector>
           <offsetVector>0 -0.00025602</offsetVector>
         </RectifiedGrid>
to refer only to a subarea.
But this is a pretty dangerous approach.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
