[gdal-dev] KMZ Support in OGR?
Simon Perkins sy at perkins.net
Sat Mar 29 09:43:15 EDT 2008
Brian Hamlin wrote:
> On Mar 28, 2008, at 10:06 AM, Simon Perkins wrote:
>>  Thanks - that would seem like a good way to go in the future, though
>> I don't have time to work on it myself...
> that may be a common story !
> the relatively light weight discussion of this that I have heard so
> far basically comes to a conclusion that since OGR writes out a pretty
> simple KML, its not worth doing the work of bringing in the new libkml
> to do that.
> Its worth noting that the Simple Features Library (that OGR is based
> on) only goes so far in mapping to KML.
> as for kmz, thats trivial.. just pipe the output to a zip program, y?
Well, it would be nice to have something that was integrated into OGR,
without having to mess around with external programs.
I think rewriting the KML driver to use the google library would be a
great idea. The current KML driver has a number of limitations - for
instance, it doesn't support reading of multi-geometries (though I think
it will write them).
Cheers,
Sy
>>  As I understand it, the BSD license allows free distribution and use
>> of source code and binaries, with or without modifications. The only
>> caveats are that (a) you mustn't remove the copyright notices from
>> the source code, (b) you must acknowledge the copyright somewhere in
>> the documentation of your library / app that uses the code, and (c)
>> you mustn't assert that the author of the original code endorses the
>> derived library / application. Is this compatible with the GDAL
>> license? Maybe the google people would be flexible if it isn't?
>>  Wouldn't this make a perfect Google Summer of Code project? Can
>> someone add it to the GDAL SoC ideas page?
>>  Cheers,
>>  Sy
>>  Clay, Bruce wrote:
>> I don't know what KMZ support is in the current GDAL KML but I
>> downloaded the libKml package from http://code.google.com/p/libkml/  and
>> it has KMZ support built in.  If anyone was going to look at an update
>> for GDAL / OGR they might want to look at that library.  The notes on
>> the website indicate that libKml is "an implementation of the candidate
>> OGC KML 2.2 standard".
>> A potential snag is that the Google library is under the BSD open source
>> license.  I don't keep track of the differences in license types so I
>> can't say if one is better than the other.
>> Bruce
>> -----Original Message-----
>> From: gdal-dev-bounces at lists.osgeo.org
>> [ mailto:gdal-dev-bounces at lists.osgeo.org ] On Behalf Of Tamas Szekeres
>> Sent: Friday, March 28, 2008 1:24 PM
>> To: Simon Perkins
>> Cc: gdal-dev at lists.osgeo.org
>> Subject: Re: [gdal-dev] KMZ Support in OGR?
>> Simon,
>> I'm not sure whether the zip file record structure is implemented in
>> zlib or not. If the latter is the case implementing this would be
>> slightly beyond the scope of GDAL. There are several projects out
>> there to provide such API for various kind of languages.
>> Best regards,
>> Tamas
>> 2008/3/28, Simon Perkins <sy at perkins.net> :
>> Hi,
>>  Does the OGR KML driver support reading and/or writing of KMZ files?
>>  KMZ files are simply zipped KML files which allow smaller file sizes
>> and
>>  bundling of multiple files in one package. I think that google earth
>>  uses the format by default.
>>  Since GDAL already includes zlib, I would think that adding support
>> for
>>  this would be pretty simple, if it's not there already. Anyone
>> planning
>>  on doing this?
>>  Cheers,
>>  Simon
>>  _______________________________________________
>>  gdal-dev mailing list
>>  http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> This message and any enclosures are intended only for the addressee.
>> Please
>> notify the sender by email if you are not the intended recipient.  If
>> you are
>> not the intended recipient, you may not use, copy, disclose, or
>> distribute this
>> message or its contents or enclosures to any other person and any
>> such actions
>> may be unlawful.  Ball reserves the right to monitor and review all
>> messages
>> and enclosures sent to or from this email address.
