[gdal-dev] What options for display of high-quality ortho's via WMS?
Roger André
randre at gmail.com
Fri May 2 00:20:04 EDT 2008
Throwing out a general question to this list because I know that many of us
use a variety of different applications to "get the job done", but use the
GDAL tools as the common unifier (at least I like to think so). I'm putting
together a Mapserver-driven web map that uses OpenLayers to get data via
WMS. It's all working quite nicely, except for my aerial photo layer, which
I am not incredibly pleased with. Despite using every tweak I could find
(convert from RGB to 8-bit with pct2rgb.py, use OUTPUTFORMAT with
GD/PNG, and use "DITHER=YES" in mapfile, I cannot get a very high quality
rendition of the photo layer in my WMS output. It looks grainy in areas
with solid color and generally a bit "pixelly". So I have a couple of
questions.
1. Is some loss of image quality an unavoidable side-effect of using
Mapserver?
2. If not 1, then are there other tweaks that can be done to further improve
the quality of my output? (Note that I intend to use Tilecache, so maybe
slow initial performance may is an acceptable trade off, I dunno.)
3. If yes to 1, then what other open source tools do a better job of
rendering photo data? (I intend to test some of the data in GeoServer, but
I haven't done so yet.)
Thanks in advance for your feedback.
Roger
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080501/2bb44d35/attachment.html
