[gdal-dev] Java Bindings
Daniele Romagnoli daniele.romagnoli at geo-solutions.it
Fri May 2 10:28:17 EDT 2008
Hi Joe,
the main "problem" of a java bindings build is that it depends on which
formats you want GDAL will support. Depending on your needs, you should
build GDAL with support for several formats (which may also include external
libraries) and then you should build java bindings using SWIG, leveraging on
that GDAL build.
Anyway, we have built some java bindings for a basic GDAL version
(windows/linux) and GDAL with support for MrSID and ECW (windows/linux).
Actually we dont have a ready to use release of these libraries, but you can
find this work and how to obtain the libs on our ImageIO-Ext project (
https://imageio-ext.dev.java.net/). [See the setup guide as "guest" user
without password.]
Hope this helps. Let me know if you need more info/help.
Regards,
Daniele
On Fri, May 2, 2008 at 4:14 PM, Joe <qbproger at gmail.com> wrote:
> Hi,
> I was wondering if there is a distribution of the java bindings
> already built, with support for different platforms (win32, linux,
> linux 64-bit)?
> I've googled for a while, but all I could find was the swig
> instructions.  Is there anything already built?
> Thanks,
> Joe
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Eng. Daniele Romagnoli
Software Engineer
GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
Italy
phone: +39 0584983027
fax: +39 0584983027
mob: +39 328 0559267
http://www.geo-solutions.it
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080502/e76477a9/attachment.html
