[gdal-dev] offset and scale
Mon May 5 15:51:09 EDT 2008
Trent M Hare wrote:
> I have a set of existing 16bit geoTiffs.  While converting there was no
>  "Offset" or "Scale" in the converted image. I now need to add a Offset
> and Scale values postmortem such that at least the label is correct.  Is
> there a clever way to do this on the existing images or even maybe via a
> created VRT format and a convert again?
Trent,
You can add scale and offset in a .VRT file using the <Offset> and
<Scale> tags per the VRT tutorial.
eg.
gdal_translate abc.tif -of VRT abc.vrt
... edit abc.vrt ...
... insert something like the following as children of <VRTRasterBand> ...
     <Scale>0.25</Scale>
     <Offset>100</Offset>
gdal_translate abc.vrt abc2.tif
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
