[Gdal-dev] VS.NET 2005 - Bulding libecwj2-3.3 from source
Maksim Sestic max at geoinova.com
Wed May 7 06:35:54 EDT 2008
Mateusz, Jeff,
Thank you both for helping me out solve this, it worked more or less per
Jeff's instructions found at:
http://lists.maptools.org/pipermail/fwtools/2008-April/001213.html This was
valuable one, shouldn't it find it's way on "Building GDAL with ECW support
on Windows" at http://trac.osgeo.org/gdal/wiki/ECW wiki page? I could post
it myself but I'm really not too competent to write about VC++ issues :-)
Regards,
Maksim Sestic
Maksim Sestic wrote:
> Hi all,
> I'm trying to figure out how to build libecwj2-3.3 from source, using
> VS.NET 2005. Source archive downloaded from ERMapper site is
> ImageCompressionSDKSourceCode3.3Setup_20070509.zip. Since C/C++ is not my
> native dev platform, I'm stuck with compiler reporting missing winhttp.h
> header file.
> Is there any suggestion what steps to take to actually build libecwj2-3.3
> from source? :-)
> Regards,
> Maksim Sestic
View this message in context: http://www.nabble.com/VS.NET-2005---Bulding-libecwj2-3.3-from-source-tp17063302p17101824.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
