[gdal-dev] OGR merge polygon capabilities
Christopher Schmidt
crschmidt at metacarta.com
Thu May 8 02:36:30 EDT 2008
On Wed, May 07, 2008 at 10:04:55PM -0400, Clay, Bruce wrote:
> Are there any capabilities built into OGR to walk layer and find all
> overlapping polygons and merge them into multiple larger polygons?
I think that the "Dissolve" action from WPServer does this, using OGR:
http://code.google.com/p/webprocessingserver/source/browse/trunk/webprocessingserver/WebProcessingServer/Action/OGRGeos.py#sr_62_67
Essentially:
* Add all your geometries to a geometry collection
* Buffer the geometry collection (using GEOS Buffer op)
* Loop through the resulting geometry (if it's a collectino or
multipoly) and split the geoms back up.
-- Chris
> Bruce
> This message and any enclosures are intended only for the addressee. Please
> notify the sender by email if you are not the intended recipient. If you are
> not the intended recipient, you may not use, copy, disclose, or distribute this
> message or its contents or enclosures to any other person and any such actions
> may be unlawful. Ball reserves the right to monitor and review all messages
> and enclosures sent to or from this email address.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Christopher Schmidt
MetaCarta
