Hi, In order to find the bounding box of polygons (defined in a shapefile), I guess I need to find the minimum x and y coordinates and maximum x and y coordinates and then to form the four corners. In case somebody has already done this, would you like to share your thoughts or code? Thanks Xiaodong
