[gdal-dev] Smoothing polygons
Howard Butler
hobu.inc at gmail.com
Mon May 12 17:33:47 EDT 2008
You want a Douglas-Peucker algorithm? http://mappinghacks.com/2008/05/05/douglas-peucker-line-simplification-in-python/
DP generalization is in GEOS too, I think, but not available to the C
API.
On May 12, 2008, at 4:26 PM, Clay, Bruce wrote:
> With the help of some folks on this forum I have successfully
> managed to create polygons that represent the coverage area of a set
> of geo-data points. The operation does quite smoothly and fairly
> fast. I am don’t to one final operation that I have searched both
> GDAL/OGR and GEOS API and have not found.
> Before I start coding I wanted to ask if anyone knows of an existing
> operation that I missed that will smooth the edges and simplify the
> resultant polygons. The attached files show the buffered points as
> overlapping polygons and the final merged polygon. The merged set
> is a result of applying a buffer to a GeometryCollection. If the
> images make it though the mail filters you can see that the edges of
> the polygons have a scalloped effect. If I can smooth the edged it
> should reduce the stored geometry size.
> Any thoughts would be greatly appreciated.
> Bruce
> This message and any enclosures are intended only for the
> addressee. Please
> notify the sender by email if you are not the intended recipient.
> If you are
> not the intended recipient, you may not use, copy, disclose, or
> distribute this
> message or its contents or enclosures to any other person and any
> such actions
> may be unlawful. Ball reserves the right to monitor and review all
> messages
> and enclosures sent to or from this email address.
> polygons
> .JPG><merged.JPG>_______________________________________________
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
