[gdal-dev] creating multi banded imagery
Lucena, Ivan
ivan.lucena at pmldnet.com
Mon May 12 20:45:03 EDT 2008
Jared,
The forth parameter on "Create" is actually the number of bands but will
not going to work for driver/formats that does not support multi-band.
If you want to use NITF you should check the docs.
>>> dst = driver.Create(' ', 10, 10, *10*, GDT_UInt16)
Best regards,
Ivan
Refs.:
http://www.gdal.org/classGDALDriver.html#191dc4a5c8f48c1dea4083c711b8f7c4
http://www.gdal.org/formats_list.html
Jared Rubin wrote:
> Dear group,
> Is there a gdal format that allows for n-banded imagery? So something like
> the following in python in which I attempt to create a 10 banded image?
> thanks
> import sys,os,string,shutil
> import osgeo.gdal
> from osgeo.gdalconst import *
> import numpy
> from numpy import *
> buf = zeros((10,10))
> driver = osgeo.gdal.GetDriverByName('NITF')
> dst = driver.Create('tmp.nitf', 10, 10, 1, osgeo.gdal.GDT_UInt16)
> dst.GetRasterBand(1).WriteArray(buf)
> dst.GetRasterBand(2).WriteArray(buf)
> dst.GetRasterBand(3).WriteArray(buf)
> dst.GetRasterBand(4).WriteArray(buf)
> dst.GetRasterBand(5).WriteArray(buf)
> dst.GetRasterBand(6).WriteArray(buf)
> dst.GetRasterBand(7).WriteArray(buf)
> dst.GetRasterBand(8).WriteArray(buf)
> dst.GetRasterBand(9).WriteArray(buf)
> dst.GetRasterBand(10).WriteArray(buf)
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
