[gdal-dev] gdal_grid: taking a value from feature attribute
Andrey Kiselev
dron at ak4719.spb.edu
Sun May 18 04:42:39 EDT 2008
Frank,
On Sat, May 17, 2008 at 12:03:05PM -0400, Frank Warmerdam wrote:
> If you are willing to do a bit of extra work I would suggest that the
> argument to -a be treated as an attribute name, but if it is not found
> *and* matches an algorithm name it be used as the algorithm with a
> warning so folks get used to use the new algorithm flag.
That is what I am calling overintelligence!
> Generally speaking I am loath to change commandline arguments because
> it breaks scripts. With gdal_grid you at least have the situation
> that the program is very new, so it will likely not be "deeply baked"
> into many scripted systems yet.
Yes, that is why I am thinking it is not too harmful.
Best regards,
Andrey
Andrey V. Kiselev
ICQ# 26871517
