[gdal-dev] ogrinfo on JOINed layer empty
Frank Warmerdam
warmerdam at pobox.com
Mon May 19 17:14:27 EDT 2008
William Kyngesburye wrote:
> While testing some connections for a Mapserver map file, I'm finding
> that ogrinfo is not showing any info (layers, fields, features) on
> JOINed layers.
> A connection that works in Mapserver:
> CONNECTION "/"
> DATA "SELECT * FROM some_shapefile LEFT JOIN
> 'MYSQL:some_database,host=localhost,user=some_user,tables=some_table'.some_table
> ON some_shapefile.id = some_table.id"
> but in ogrinfo (on the Mapserver computer, so it's still local):
> ogrinfo -al -so . "SELECT * FROM some_shapefile LEFT JOIN
> INFO: Open of `.'
> using driver `ESRI Shapefile' successful.
> It does not show any of the fields from the shapefile or the JOINed
> MySQL table. I get exactly the same output on a bad JOIN (or other
> non-existent shapefile layer).
> CPL_DEBUG=ON doesn't show any helpful debug messages, just (there are 5
> shapefiles in the folder):
> OGR: GetLayerCount() = 5
> Any hints on how to get ogrinfo to show JOINed layer info? I think I've
> seen this work in the past.
William,
There are two issues here.
1) ogrinfo does not report an error when you pass it a layer name that doesn't
exist on the commandline.
2) You aren't passing the SQL statement you want evaluated using the sql
commandline switch. Try:
ogrinfo -al -so . -sql "SELECT * ...'
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
