[gdal-dev] Re: converting KML to CSV
Tim Michelsen
timmichelsen at gmx-topmail.de
Tue May 20 16:24:52 EDT 2008
> The CSV driver does not support writing geometries, though I can see some
> support for this might be desirable.
May I enter a request for it?
I also suggest that CSV reader accepts the following formats as well:
8.1;0.25;First point
49.2;1.1;Second point
47.5;0.75;Third point
Excel writes like this by default and many programs use it as well. If
you want the traditional format -- the only one accepted by OGR -- you
need to use the more advanced CSV export in openoffice calc.
Kind regards,
Tim
