[Gdal-dev] gdal_grid: taking a value from feature attribute
Andrey Kiselev dron at ak4719.spb.edu
Sat May 24 09:50:16 EDT 2008
On Fri, May 23, 2008 at 04:50:40PM -0700, Fodder wrote:
> Just curious if the new version of gdal_grid allowing for a shapefile
> attriubte to be used as the z field is available yet?
Yep, I just checked in the new version. You need to update from the
trunk to get it. Just use the attribute field name with the "-zfield"
option. I think that updated documentation will be available here
shortly:
 http://www.gdal.org/gdal_grid.html
Best regards,
Andrey
Andrey V. Kiselev
ICQ# 26871517
