[gdal-dev] GDAL Data dir and installed application
Frank Warmerdam
warmerdam at pobox.com
Thu May 29 22:18:38 EDT 2008
Javier Urien wrote:
> Hello,
> I am developing an application that uses GDAL. I compiled with
> MinGW+Msys on windows. I use proj4 as an external dll.
> When I install the application on a clean machine (ie not
> developement), I do not get all the georreference information I do on
> the development installation. I found that Gdal apps use the GDAL_DATA
> variable and so I tried setting it to the installation directory
> containing all the .csv gdal provides, but with no success.
> Any hints on how to accomplish this?
Javier,
Is there any possibility the PROJ.DLL isn't being found? Is it in the path?
You might try setting the CPL_DEBUG environment variable to ON to get more
information.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
