[gdal-dev] GDAL 1.5.2 RC3 and HDF
Andrew Brooks
arb at sat.dundee.ac.uk
Fri May 30 12:43:41 EDT 2008
Hi
Please don't use RC3 as final 1.5.2 until the HDF code is fixed. It is broken at
the moment and simply won't compile with the current HDF4 and hdf5 libraries. Both
HDF APIs have changed and GDAL no longer compiles. See below for my changes (not
necessary correct, especially the use of H5Gopen1, but at least it compiles!).
Andrew
% find gdal-1.5.2rc3 | xargs grep -n 'XXX.arb'
gdal-1.5.2rc3/frmts/hdf4/hdf4dataset.cpp:576: char szAttrName[H4_MAX_NC_NAME]; // XXX arb
gdal-1.5.2rc3/frmts/hdf4/hdf4dataset.cpp:743: poDS->iSubdatasetType = HS_UNKNOWN; // XXX arb
gdal-1.5.2rc3/frmts/hdf4/hdf4dataset.cpp:754: int32 aiDimSizes[H4_MAX_VAR_DIMS]; // XXX arb
gdal-1.5.2rc3/frmts/hdf4/hdf4dataset.h:54: HS_UNKNOWN // XXX arb
gdal-1.5.2rc3/frmts/hdf4/hdf4imagedataset.cpp:91: int32 aiDimSizes[H4_MAX_VAR_DIMS]; // XXX arb
gdal-1.5.2rc3/frmts/hdf4/hdf4imagedataset.cpp:205: int32 aiStart[H4_MAX_NC_DIMS], aiEdges[H4_MAX_NC_DIMS]; // XXX arb
gdal-1.5.2rc3/frmts/hdf4/hdf4imagedataset.cpp:444: int32 aiStart[H4_MAX_NC_DIMS], aiEdges[H4_MAX_NC_DIMS]; // XXX arb
gdal-1.5.2rc3/frmts/hdf4/hdf4imagedataset.cpp:1100: int32 aiDimSizes[H4_MAX_VAR_DIMS]; // XXX arb
gdal-1.5.2rc3/frmts/hdf4/hdf4imagedataset.cpp:1103: int32 aiStart[H4_MAX_NC_DIMS], aiEdges[H4_MAX_NC_DIMS]; // XXX arb
gdal-1.5.2rc3/frmts/hdf4/hdf4imagedataset.cpp:1459: int32 aiDimSizes[H4_MAX_VAR_DIMS]; // XXX arb
gdal-1.5.2rc3/frmts/hdf4/hdf4imagedataset.cpp:1466: char szAttrName[H4_MAX_NC_NAME]; // XXX arb
gdal-1.5.2rc3/frmts/hdf4/hdf4imagedataset.cpp:1569: int32 aiDimSizes[H4_MAX_VAR_DIMS]; // XXX arb
gdal-1.5.2rc3/frmts/hdf4/hdf4imagedataset.cpp:1576: char szAttrName[H4_MAX_NC_NAME]; // XXX arb
gdal-1.5.2rc3/frmts/hdf4/hdf4imagedataset.cpp:1624: int32 aiDimSizes[H4_MAX_VAR_DIMS]; // XXX arb
gdal-1.5.2rc3/frmts/hdf4/hdf4imagedataset.cpp:1693: int32 aiDimSizes[H4_MAX_VAR_DIMS]; // XXX arb
gdal-1.5.2rc3/frmts/hdf4/hdf4imagedataset.cpp:1909: int32 iStart[H4_MAX_NC_DIMS], iEdges[H4_MAX_NC_DIMS]; // XXX arb
gdal-1.5.2rc3/frmts/hdf4/hdf4imagedataset.cpp:2293: poDS->iSubdatasetType = HS_UNKNOWN; // XXX arb
gdal-1.5.2rc3/frmts/hdf4/hdf4imagedataset.cpp:2614: memset( poDS->aiDimSizes, 0, sizeof(int32) * H4_MAX_VAR_DIMS ); // XXX arb
gdal-1.5.2rc3/frmts/hdf4/hdf4imagedataset.cpp:2625: char szAttrName[H4_MAX_NC_NAME]; // XXX arb
gdal-1.5.2rc3/frmts/hdf4/hdf4imagedataset.cpp:2737: char szAttrName[H4_MAX_NC_NAME]; // XXX arb
gdal-1.5.2rc3/frmts/hdf4/hdf4imagedataset.cpp:3034: int32 aiDimSizes[H4_MAX_VAR_DIMS]; // XXX arb
gdal-1.5.2rc3/frmts/hdf4/hdf-eos/GDapi.c:10873: int32 dims[H4_MAX_VAR_DIMS]; /* Field/SDS dimensions */ // XXX arb
gdal-1.5.2rc3/frmts/hdf4/hdf-eos/SWapi.c:11415: int32 dims[H4_MAX_VAR_DIMS]; /* Field/SDS dimensions */ // XXX arb
gdal-1.5.2rc3/frmts/hdf5/hdf5dataset.cpp:243: poDS->hGroupID = H5Gopen1( poDS->hHDF5, "/" ); // XXX arb
gdal-1.5.2rc3/frmts/hdf5/hdf5dataset.cpp:442: if( ( hGroupID = H5Gopen1( hHDF5, pszObjName )) == -1 ) { // XXX arb
gdal-1.5.2rc3/frmts/hdf5/hdf5dataset.cpp:471: if( ( hDatasetID = H5Dopen1( hHDF5, pszObjName )) == -1 ) { // XXX arb
gdal-1.5.2rc3/frmts/hdf5/hdf5dataset.cpp:676: hGroupID = H5Gopen1( hHDF5, poH5Object->pszPath); // XXX arb
gdal-1.5.2rc3/frmts/hdf5/hdf5dataset.cpp:678: ret = H5Aiterate1( hGroupID, NULL, // XXX arb
gdal-1.5.2rc3/frmts/hdf5/hdf5dataset.cpp:687: hDatasetID = H5Dopen1(hHDF5, poH5Object->pszPath); // XXX arb
gdal-1.5.2rc3/frmts/hdf5/hdf5dataset.cpp:690: ret = H5Aiterate1( hDatasetID, NULL, // XXX arb
gdal-1.5.2rc3/frmts/hdf5/hdf5dataset.cpp:872: hGroupID = H5Gopen1( hHDF5, "/" ); // XXX arb
