[gdal-dev] Problem with libTiff on Solaris 10
Even Rouault
even.rouault at mines-paris.org
Fri May 30 13:18:31 EDT 2008
Hum, I'm not a specialist of SPARC at all, but doesn't this architecture
require proper memory alignment accesses ?
I say that because the crash on " *(uint32*)n=(uint32)o->tdir_count " could be
easily explained if the memory address pointed by 'n' is not aligned on a 4
byte address....
In the next few lines of the code extract Dan Greve has quoted, I
see "_TIFFmemcpy(n,&o->tdir_offset,4)" which is a safer way of dealing with
this alignment problems...
It looks like a libtiff problem, so I add the libtiff mailing list in CC too.
Best regards,
Even
RE: [gdal-dev] Problem with libTiff on Solaris 10
De :
"Gong, Shawn (Contractor)" <Shawn.Gong at drdc-rddc.gc.ca>
À :
"Dan Greve" <grevedan at hotmail.com>, gdal-dev at lists.osgeo.org
Date :
Aujourd'hui 18:54:44
Dan and list,
This error looks very similar to what I have experienced on our Sun machine,
trying to build and run gdal 1.5.1.
Our Sun system is SPARC Solaris 9 64-bit.
Error message when Python codes call "gtiff_driver.CreateCopy( fname,
vrtds, ...)"
ERROR 1: /home/sgong/../working_dir/test2.tif:No space to read TIFF directory
ERROR 1: TIFFReadDirectory:Failed to read directory at offset 8 Bus error
(core dumped)
thanks,
Shawn
________________________________________
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Dan Greve
Sent: Friday, May 30, 2008 11:51 AM
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] Problem with libTiff on Solaris 10
Greetings,
I am using the latest stable build, gdal-1.5.1 on a SPARC Solaris 10 64-bit
system. It is configured with the default drivers, but is
using --with-jpeg=internal --with-libtiff=internal --with-geotiff=internal.
Using the 32-bit compiler options and libraries, I can successfully build
libgdal.so and the utility programs. However, when trying to do a
gdal_translate from one simple uncompressed 3-band geotiff into another
simple uncompressed 3-band geotiff, I get a "bus error" segfault. Also, if
the output tiff already exists I get two errors. "No space to read tiff
directory" and "TiffReadDirectory: failed to read directory at offset 8". A
quick google revealed two similiar errors, here and here. Diving into the
debugger, the problem seems to lie in the tif_dirwrite.c, starting with line
755. I believe it's due to _TIFFmalloc not allocating memory properly. The
crash actual occurs on line 781, *(uint32*)n=(uint32)o->tdir_count;
o->tdir_count is valid, but setting n to any value causes a segfault, as
though TIFFmalloc did not allocate the whole requested 186 bytes. Any ideas?
<snip file=tif_dirwrite.c>
dirmem=_TIFFmalloc(dirsize);
if (dirmem==NULL)
TIFFErrorExt(tif->tif_clientdata,module,"Out of memory");
goto bad;
if (!(tif->tif_flags&TIFF_BIGTIFF))
uint8* n;
TIFFDirEntry* o;
n=dirmem;
*(uint16*)n=ndir;
if (tif->tif_flags&TIFF_SWAB)
TIFFSwabShort((uint16*)n);
n+=2;
o=dir;
for (m=0; m<ndir; m++)
*(uint16*)n=o->tdir_tag;
n+=2;
*(uint16*)n=o->tdir_type;
n+=2;
TIFFSwabLong((uint32*)n);
n+=4;
_TIFFmemcpy(n,&o->tdir_offset,4);
n+=4;
o++;
*(uint32*)n = (uint32)tif->tif_nextdiroff;
</snip>
-- Dan Greve
-- Software Engineer
-- Northrop Grumman Corp.
