[Tiff] Re: [gdal-dev] Problem with libTiff on Solaris 10
Even Rouault even.rouault at mines-paris.org
Sat May 31 11:30:11 EDT 2008
Dan,
Your fix is not the right one. But I recognize that my previous suggestion
could lead into error.
In fact, tdir_count field is a uint64 in libtiff 4.0.
So the correct fix is :
uint32 nTemp = (uint32)o->tdir_count;
_Tiffmemcpy(n, &nTemp, 4);
Even
RE: [Tiff] Re: [gdal-dev] Problem with libTiff on Solaris 10
De :
Dan Greve <grevedan at hotmail.com>
  À :
Bob Friesenhahn <bfriesen at simple.dallas.tx.us>, Even Rouault
<even.rouault at mines-paris.org>
  CC :
gdal-dev at lists.osgeo.org, tiff at lists.osgeo.org, Andy Cave
<andy.cave at hamillroad.com>, mailing list <tiff at lists.maptools.org>
  Date :
Aujourd'hui 16:49:15
Sure enough, the pointer n is not null, and throws a sigsegv fault. Aftern
changing from
*(uint32*)n=(uint32)o->tdir_count;            TO
_TIFFmemcpy(n, &o->tdir_count, 4)
The execution passes this point, but where as *(uint32*)n should be 1, it is
0. This causes errors later in the GDALOpen call on the tiff dataset, which
fails with error "TiffFetchNormalTag:incorrect count for "SamplesPerPixel".
debugging continues....
-- Dan Greve
-- Software Engineering
-- Northrop Grumman Corp.
