[gdal-dev] gdal translate error converting ArcGRID binary to ASCII
P Kishor
punk.kish at gmail.com
Sat May 31 14:25:26 EDT 2008
I have a few ArcGRID binary files (.adf extension) that I want to
convert to ArcGRID ASCII (so I may open them with QGIS).
An old email from Frank W indicates this can be done with gdal_translate. See
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0405/msg00005.html
I was, however, unable to do this successfully. Here is my saga --
[01:45 PM] ~/Data/climate_change/cartagena_arcgrid$ gdal_translate
Usage: gdal_translate [--help-general]
[-ot {Byte/Int16/UInt16/UInt32/Int32/Float32/Float64/
CInt16/CInt32/CFloat32/CFloat64}] [-strict]
[-of format] [-b band] [-outsize xsize[%] ysize[%]]
[-scale [src_min src_max [dst_min dst_max]]]
[-srcwin xoff yoff xsize ysize] [-projwin ulx uly lrx lry]
[-a_srs srs_def] [-a_ullr ulx uly lrx lry] [-a_nodata value]
[-gcp pixel line easting northing [elevation]]*
[-mo "META-TAG=VALUE"]* [-quiet] [-sds]
[-co "NAME=VALUE"]*
src_dataset dst_dataset
GDAL 1.5.1, released 2008/03/14
The following format drivers are configured and support output:
VRT: Virtual Raster
GTiff: GeoTIFF
NITF: National Imagery Transmission Format
HFA: Erdas Imagine Images (.img)
ELAS: ELAS
AAIGrid: Arc/Info ASCII Grid
DTED: DTED Elevation Raster
PNG: Portable Network Graphics
JPEG: JPEG JFIF
MEM: In Memory Raster
GIF: Graphics Interchange Format (.gif)
XPM: X11 PixMap Format
BMP: MS Windows Device Independent Bitmap
PCIDSK: PCIDSK Database File
PCRaster: PCRaster Raster File
ILWIS: ILWIS Raster Map
SRTMHGT: SRTMHGT File Format
Leveller: Leveller heightfield
Terragen: Terragen heightfield
PNM: Portable Pixmap Format (netpbm)
ENVI: ENVI .hdr Labelled
EHdr: ESRI .hdr Labelled
PAux: PCI .aux Labelled
MFF: Vexcel MFF Raster
MFF2: Vexcel MFF2 (HKV) Raster
BT: VTP .bt (Binary Terrain) 1.3 Format
IDA: Image Data and Analysis
ERS: ERMapper .ers Labelled
FIT: FIT Image
RMF: Raster Matrix Format
RST: Idrisi Raster A.1
INGR: Intergraph Raster
GSAG: Golden Software ASCII Grid (.grd)
GSBG: Golden Software Binary Grid (.grd)
USGSDEM: USGS Optional ASCII DEM (and CDED)
ADRG: ARC Digitized Raster Graphics
[01:45 PM] ~/Data/climate_change/cartagena_arcgrid$ ls *.adf
76980974\76980974\dblbnd.adf* 76980974\76980974\prj.adf*
76980974\76980974\w001001.adf*
76980974\76980974\hdr.adf* 76980974\76980974\sta.adf*
76980974\76980974\w001001x.adf*
[01:46 PM] ~/Data/climate_change/cartagena_arcgrid$ gdal_translate -of
AAIGrid 76980974\\76980974\\w001001.adf out.grd
ERROR 4: `76980974\76980974\w001001.adf' not recognised as a supported
file format.
GDALOpen failed - 4
`76980974\76980974\w001001.adf' not recognised as a supported file format.
I am on an Intel Macbook Pro with Mac OS X 10.5.3.
Puneet Kishor
