[gdal-dev] GDAL/OGR 1.6.0 Beta 1 Available
William Kyngesburye woklist at kyngchaos.com
Mon Nov 3 09:50:30 EST 2008
On Nov 2, 2008, at 8:06 PM, William Kyngesburye wrote:
> One bug that hasn't had any action taken:
> http://trac.osgeo.org/gdal/ticket/1242
> I wonder - I build OGDI with proj support.  For use only in GDAL, is
> that necessary?  If not, then I could remove PROJ from my OGDI and
> this bug will be meaningless, to me at least.
OK, reviewing the OGDI configuration, I see that PROJ is required.
Can't build without it.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
