[gdal-dev] Mapinfo TAB Files and DateTime
Daniel Morissette dmorissette at mapgears.com
Wed Nov 5 10:14:28 EST 2008
Looks like the problem may be in the MITAB driver itself: DateTime
support has been added for writing only but has been skipped for reading.
I have reopened ticket 2585 about this, but it will be at least a couple
of days before we have time to work on it:
   http://trac.osgeo.org/gdal/ticket/2585
Daniel
Dale Harris wrote:
> I am using GDAL 1.6 Beta with VB.NET (through ogr_csharp) to read a TAB
> file with a Date or a Date Time field and I can’t use the following to
> get the date values (they are all 0):
> .GetFeature(x).GetFieldAsDateTime(33, myyear, mymonth, myday, myhour,
> mymin, mysec, mytz)
> However if I use:
> .GetFeature(x).GetFieldAsString(33)
> I get “2008102600000”.
> Also if I try to create a new file with a datetime field it builds ok
> but the field has no values assigned to it.
> Is this due to the csharp wrapper not yet supporting datetime fields in
> Mapinfo?
> Cheers,
> **Dale Harris***
> *GIS Manager
> **Regis Resources***
> *Ground Floor
> 62 Colin Street
> West Perth WA 6005
> Direct Line (08) 9442 2207
> Fax: (08) 9442 2290
> Email: dharris at regisresources.com <mailto:dharris at regisresources.com>
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Daniel Morissette
http://www.mapgears.com/
