[gdal-dev] resampling artifacts
Brent Fraser bfraser at geoanalytic.com
Thu Nov 6 18:08:51 EST 2008
Has anyone experienced resampling artifacts using gdalwarp?
    I'm using v1.5.2, and with lanczos or cubicspline resampling, I get a vertical line and a horizontal line of seemingly random pixels about 6 pixels wide running through the center of the output image.
    I'm resampling a 16-bit tif image from 12.5 meters to 200 meters.  The other resampling methods result in an ok output image.
I've attached a png to illustrate the effect.   I thought I'd ask before filing a bug report...
Thanks!
Brent Fraser
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20081106/d7f24faf/20080731_400m_cs-0001.png
